Old 06-29-2009, 08:03 PM
DocDirk's Avatar
DocDirk DocDirk is offline
Cobra Make, Engine: West Coast-Ford Performance Solutions 533 BB
Question How high a steady temp is safe to run?
Yesterday the temp topped 105F as is often does in the summer here. I took the cobra out for a cruise midafternoon and it rose gently to stop at 210F fully hot and running on the freeway after 20-25 minutes. In town traffic caused it to rise a bit further to about 215F. Oil pressure dropped from usual 38-40# running down to about 32# while running, 20# idling.
I've optimized the cooling system by every possible move short of shrouding the front to the radiator which I will soon be doing and in ambient temps under 95F it runs very nicely from 185-195F.
Summers are really hot here; I know some of you Texans and Arizonans have high temp outdoors experience...how high can I run a stable temp. without harming the engine? Should I be measuring oil temp too? Cylinder head temps?
Thanks for any replies!
Dirk
The government giveth and the government taketh away..... if our rights are not God given then they're subject to revision!
