Old 06-30-2009, 06:34 PM
Wally68's Avatar
Wally68 Wally68 is offline
Cobra Make, Engine: G-Force
Default Fly by wire,E40 PCM Connection
I have a LS2 with a VZ HSV LS2 engine Loom and a E40 PCM also a white stickered fly by wire pedal,crank sensor plug is Black(24x reluctor).What I'm needing is the wiring diagram (Pin outs)and also where I can buy the necessary plugs from i.e. (J1 Blue connector 56 pin,throttle 6 pin connector) so I can get this pedal connected to the PCM.Any info on what is the best way to tackle this problem will be much appreciated.
