Old 11-23-2001, 07:10 AM
Coloradocobra Coloradocobra is offline
Jim,
Take a six-inch scale and set it across the block plate where the starter mounts and measure the distance to the front face of the starter gear. If you cannot simply pull the bendix out, then run it on a bench as you suggest and carefully measure the distance it extends as well as the retracted distance. I identified my problem when checking valves. As I rotated the crank, I heard a scraping at the starter. It was actually hitting the gear just sitting there. When I pulled the starter, you could see the face of the bendix was rubbing against the face of the starter gear. It must happen frequently enough for Pep Boys to stock the spacer on the shelf. I'm probably being retentive in suggesting you do all this but your frequent starter failures are suspicious! Don't just install the shim as you want to ensure that you are getting full gear contact or you'll start breaking teeth.
Good luck,
Gary
