Old 07-04-2009, 09:23 AM
Double Venom's Avatar
Double Venom Double Venom is offline
Jay,
A very proffessional product is called "Mar-Hyde". I have used it to completely change interior color The last one I did was an older Cadillac from White to Blue. Normally found in the larger autobody stores. The only secret is to have the "piece" clean and dry AND even though Mar-Hyde drys in seconds, make sure it is put on in very lite coats! Once done and totally dry it will NOT peel, crack or fade. Great stuff. (You can get it in spray cans or even quarts to be sprayed with a paint gun!)
You can check the web for it but I have always gotten it from my paint supplier- Good Luck, I know if you use it you will like it!
DV
