Old 07-06-2009, 05:53 PM
undy's Avatar
undy undy is offline
Originally Posted by SF_SN888KE View Post
Looks like the Taurus fan/shroud combo is the way to go (if it fits) and not replace the Zirgo fan with a Spal. (half the price!) But, will the Flex-a-Lite Variable Speed Control work with the Taurus fan. I was thinking of hooking it up on the High Speed side and use the Flex Variable Speed Control. Don't want to pull and rewire everything again. The Variable Speed Control worked well before the Zirgo fan took a dump.
...not sure what the Zirgo draws but I'd lay money that the Taurus or the MK8 fan draws more amps. More CFM = more AMPS. You need to call Flexalite tech and find out what amp rating that controller supports. With the Taurus or MK8 fans you'll need 40 to 45 amps continuous. I would be surprised if the flexalite unit will handle it. ..worth a call though.
Too many toys?? never!
