Old 07-08-2009, 07:58 AM
PurpleVenom's Avatar
PurpleVenom PurpleVenom is offline
Cobra Make, Engine: FFR MKII - 460 Crate with Cobra Jet heads, 750 Quick Fuel Carb, and Edelbrock Torker II Intake port matched to heads
Pulled the header last night and have confirmed that with the COBRA JET heads the FPP-1420 is the correct gasket. Now, there may be others with the same port measurements of 2.35" Tall x 1.55" which I'm sure there are many. The 1420 is what I will be using on my application. The old one was leaking on #8 and appears the gasket had hardened to a point of cracking. I recently had a dyno tune done, wonder if the added horsepower/dyno had anything to do with this gasket failure as it wasn't there prior to the dyno tune.
