Old 07-08-2009, 10:32 AM
RodKnock's Avatar
RodKnock RodKnock is offline
Originally Posted by xlr8or View Post
Rod there are footbox mods on both sides required to fit the cammer in your car and I believe the inner fender on the passenger side would need a bit influencing as well. The top corners are cut in several inches to fit the engine and the standard gas pedal setup would gone. Then there's getting 2" headers to fit in there around the steering shaft.
Can someone elaborate how the footboxes are modified? Do they take a large slice out of the sides facing the engine leaving very little of the box left and then all the pedals have to moved over to the left?
I know my headers right now are very close to the steering linkage. So does modifying the steering linkage make the angles and thus the steering worse off? I've always wanted a Cammer in a Cobra and now with the advent of the reproduction engine parts (heads, intakes, blocks, etc.) being made, it's possible to own one.....someday.
