Old 07-09-2009, 09:59 AM
jeffy's Avatar
jeffy jeffy is offline
Cobra Make, Engine: ERA 289FIA 2131, 331 stroker by Dan Dalena with 48 IDAs by Jim Inglese, AC Cars AC8 "Rosso Chiaro" (PPG Nexa code FG39) by Connecticut Custom
Originally Posted by Cobrabill View Post
No OD type trans has the strength of a Toploader.And there isn't a "internal rail" trans that will shift as smooth as a TL.
What is your "cruising RPM" and at what RPM is your advance all the way in?
You are being "comical" about the "overdrive" comment-right?
Can't remember what 70mph worked out to. My tires will be about 26.5", so you can easily look it up. I don't plan to do long highway "cruises", and I want plenty of revs for the Webers. I don't understand what "advance all the way in" means, so can't respond to that question.
The fourth gear in my setup will have the same gearing at the tires as a 1:1 top gear paired with a 3.77 rear-end, which was a common rear-end in the original competition 289s. As a consequence, my 1:1 5th gear with a 3.08 rear becomes, in effect, an overdrive relative to the original racing setup. Sorry if that concept is confusing for you, but that is how I look at it.
