Old 07-09-2009, 05:16 PM
DonC's Avatar
DonC DonC is offline
Cobra Make, Engine: ERA #684, 428 FE, TKO600
Start the engine and get it up to operating temp then with the engine running disconnect and cap the vacuum line then read the fuel pressure at the regulator. The EEC-IV is generally set up to run 40lbs without the vacuum line attached.
Sounds like you have a Mass_Flo.
DonC
