Old 07-09-2009, 11:01 PM
DonC's Avatar
DonC DonC is offline
Cobra Make, Engine: ERA #684, 428 FE, TKO600
Problem with the A9 series ECU's is that the only way to tune them is with an add on chip. You already have one in the J3 port of the ECU and it's in all probability a Moates F3. What you'll have to do once you've insured all the mechanicals are sound is find someone who can get the binary file that is currently on the F3 chip copied off. Once you have that anyone who works on tuning Ford ECU's can modify the tune for you. Once the tune is modified and you're happy with it you just burn a new F3 chip, plug it in and go.
DonC
