Thread: Wheel Probs
Old 07-11-2009, 07:27 AM
macloft macloft is offline
Greg How many mm are you out by. As like Mike says little bit of the caliper (i removed the logo) a little bit off the wheel, might be enough. Hopefully it is not the 15mm that your spacer is.
ROG246 The using of weights while in Gregs wheel seems alot even when you balance heavy side of tyre to light side of wheel I still needed a number of weights. Is this not just the accepted way to balance a wheel tyre combo. Especially when the wheels we play with are so wide. What else do you do
Bruce
