Old 07-13-2009, 01:06 PM
Dangerous Doug's Avatar
Dangerous Doug Dangerous Doug is offline
Cobra Make, Engine: ERA 289 FIA #2108
I recently upgraded my brakes from GM (Camaro) brakes to SSBC A185S's, and the pedal is nice and firm. The Camaro brakes always felt a little mushy, and I thought I had air in the lines (even after pushing a ton of fluid through on bleeding). I had a mechanic check it out and he verifiied that the mushy brake sensation was common to the Camaro calipers, and that I had no air in my lines. The Camaro calipers have a single, large piston, wherein the SSBC's have dual smaller pistons. The net result is I push less fluid through to clamp them down.
This thread is right on. The spongy feel is coming from either too small of a master cylinder or too large of caliper pistons. I think a master cylinder replacement would be cheaper than replacing your calipers.
DD
Dangerous Doug
"You're kidding, right?"
