Old 07-13-2009, 03:37 PM
FatBoy's Avatar
FatBoy FatBoy is offline
Cobra Make, Engine: Kirkham #523, 427 S/O
Why is this such a difficult problem?
As has already been said, it isn't, you just have to use the correct switch, which is available from here:
Wiper Switch
It is then simply a matter of running a few wires from the motor to the switch.
However, I did find that mine parked the wrong end of the sweep. This is easily corrected by rotating the gear drive 180 degrees on its pinion.
Paul
