Old 07-13-2009, 03:48 PM
patrickt patrickt is offline
Originally Posted by FatBoy View Post
As has already been said, it isn't, you just have to use the correct switch, which is available from here:
Wiper Switch
It is then simply a matter of running a few wires from the motor to the switch.
However, I did find that mine parked the wrong end of the sweep. This is easily corrected by rotating the gear drive 180 degrees on its pinion.
Paul
Ahh, but if you should happen to have a switch like mine instead?
