Old 07-14-2009, 07:19 AM
Chaplin's Avatar
Chaplin Chaplin is offline
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Originally Posted by Jim Holden View Post
Just interested; Why the switch?
The Richmond Gear 5th gear is 1:1, whereas the Tremec 600 5th is .64 (or .82) Depending on your rear axle ratio, the change will result very different characteristics. Wouldn't it be cheaper to swap out the rear?
I've used both trans in my ERAs and frankly, I thought the Richmond trans with a 3.08 rear was ideal. The Tremec needs at least a 3:54 or 3.77 to work. I have a Tremec with a .82 in my FIA with a 3.31 rear and I rarely use 5th.
Jim
PS: You will also need a bellhousing/trans spacer if you are putting a Tremec behind an FE with Lakewood Bellhousing
Jim-
I have a Tremec in mine with the .82 5th and the 3.31 rear end and use 5th all of the time- doing 70 I am turning right around 2500 rpm. My only complaint with the Tremec- which has been fixed on the newer TKO 600s- is
1st gear. In my trans, 1st is 3.27, which is too low (for normal driving I need to shift by 25 mph or so). I think the TKO 600s now have the 2.87 1st, which would be much better. But other than the 1st gear ratio, the rest of the gears are very good.
Replica is not a dirty word.
