Old 07-14-2009, 01:35 PM
Double Venom's Avatar
Double Venom Double Venom is offline
cpteddie
Just so you get a confirmation, the dies, etc., did show up! Both letters and numbrs-nice set.. You might have to buy a bigger tool chest when you're all done! AND, if one is good is two better? Must be and thank you.
(Found the real reason why the 175 amp main fuse blew today.... finalizing under the dash, gas pedal is done and is , well we'll let you make the final call on that one! Short.... Actually it was a short and not arching as I at first thought....John moved the small fuse box that was under the dash (3-fuses) and ended up touching the hot/feed bolt against the choke cable when the dash was put back in!) That fuse box is now GONE!. Just the main box in the trunk now! Bettter this way anyway.
KLOTZ is praying we have your car until the 25th! They want it in their show! They even have a portable Dyno in case you and or George show with the Willy's Gonna be some noise in this town that day!
LOOK OUT HART/PENTWATER!
DV
