Thread: V-Belts
Old 07-14-2009, 06:07 PM
cavedog57's Avatar
cavedog57 cavedog57 is offline
Cobra Make, Engine: NAF 427, 331ci, 4 spd, 3.55s
Default Gilmer belt concerns and proper tension
I have a Gilmer drive setup, but I am worried about the long term impact of that on the alternator bearings, even with appropriate tension.
I did change my water pump to standard rotation, and fitted a Gilmer set up. This works fine but I am worried about the longer term impact of that on the alternator bearings and its balance.
Merv
Hi Merv,
Could you elaborate on your Gilmer belt concerns a little bit? Am running a new Gilmer belt setup and am already experiencing problems w/ the alternator -- have what looks like a carbon buildup on a frame rail near the alternator (brush material?) and the bearings are going (all within 500 miles). Tension? Would like to know how much tension is appropriate -- seems like the belt either flaps madly or is too tight.
Thanks, Dave
If you can't be good, be careful.
Dave
