Old 07-17-2009, 12:11 PM
jdean's Avatar
jdean jdean is offline
There are 2 things I discovered since then...1 is that gasoline percolation temperatures can range from as low as 100 degrees up to 400 degrees....2 is that in the larger metro areas they change to a "summer blend" of gasoline that may move the percolation point towards the lower end of the boiling point scale.
6th generation Texan....
