  #23 (permalink)
Old 07-17-2009, 06:17 PM
Barry_R Barry_R is offline
That graph is actually very similar to the one from the MSD billet distributor instructions. The combination of blue and silver springs is one of my personal favorites. Whats happening is that at cranking speed you have minimal advance so it cranks easily.
At idle speeds of +/- 1000RPM you have a modest amount of advance because of the light springs that you can set to the desired 20ish for light throttle off-idle driving.
After that 1300or so RPM it advances in a non-linear fashion because the real light silver spring gets stretched out sooner than the blue one. You limit the max amount of advance by using different stop bushings - the black one gives the least amount of distributor advance - another favorite...
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
