Old 07-22-2009, 11:27 AM
CSXDreamer CSXDreamer is offline
Thanks for the tip 133 bus: I had done this previously when I had a new 1" bore master cylinder installed. My front calipers put the bleed hole in the cylinder at the 1:00 o'clock position, but I have to remove both pins to get the right rotation. I can keep enough of the pads on the disc to prevent over movement. I'll try this next.
