Old 07-22-2009, 12:27 PM
Curt C.'s Avatar
Curt C. Curt C. is offline
Cobra Make, Engine: Classic Roadster; 351W
I had a similar problem years back. Turns out that the push rod was not completely lined up right with the which would cause some minor side loading in the cylinder. After a period of time, aluminum would flake off into the fluid and blow the seals. Check you alignment while you have it apart.
Edit: My vehicle too is a CR. The firewall is not very flat where pedal mates up to the cylinder. Exactly my problem
