Old 07-24-2009, 05:44 AM
bkozlow bkozlow is offline
Cobra Make, Engine: built the molds and body composite construction
See about having your present disc refaced with new disc material. Check your local area for clutch and brake refacing facilities. Ask them, what facing material they would recommend for the type of driving you are doing. See if, you can get from McLeod what the thickness of the disc should be as it will be helpful for the the selection of the new facing.
I had a racing three plate Borg and Beck clutch that lastest 2,000 miles on the street. It was either in or out, period! We refaced the discs with the facings from a VW and it was still going strong after 12,000 street miles.
Just a suggestion.
Billk
