Old 07-24-2009, 09:06 AM
Got the Bug's Avatar
Got the Bug Got the Bug is offline
acindrich,
It's very possible that you don't need to run an oil cooler at all on your car. My suggestion for using the cardboard, was a temporary fix/test to see if you could get the oil up to temp. Thrown a piece of cardboard on the car and see if you notice a change.
During the winter months, I run a thin piece of black rubber mat with some holes drilled in it. You wouldn't even notice it unless I pointed it out. As Bob mentioned, the oil thermostat may not work if it's extremely cold out.
Doug
