Thread: bleeding clutch
Old 07-24-2009, 09:46 PM
Got the Bug's Avatar
Got the Bug Got the Bug is offline
Originally Posted by maxum_101 View Post
no replys??? no one ever try this? will this even work on an SPF cobra set up?
also... i was told its brake fluid that is used in the clutch m/c not hyd fluid
is that right?
Correct. Regular DOT3 brake fluid is what you want to use. I didn't look at the videos, but just go old school. One person pumping the clutch pedal and the other below the car opening the bleeder valve. Slide piece of rubber hose over the bleeder and so you don't make a mess.
Doug
