Old 07-25-2009, 12:39 AM
Mando's Avatar
Mando Mando is offline
Gregg/Tenrocca, have you guys cut the rollbar rubbers at an angle so they sit on the body without the need of the ally rings on top to keep them in position? If so, what did you use and when in position is the join between the the rubber and metal constant? I used a stanley knife and its pretty good but can I improve the join using a dremel for example? The rubber doesnt like having thin amounts, say less than 1/2mm removed using an extremely sharp knife.
Regards.
Regards.
Mando
