Old 07-26-2009, 09:33 AM
mikeforte mikeforte is offline
Hi Mike,
If you have a stock 1 3/8" toploader you have a 2.32:1 1 gear x 3.56 rearend you're at best the very minimum of 8.25:1 overall 1st gear ratio.
The 262 @ .050 is a BIG cam not to even thing of lobe sepataion. Unless you are roadracing your cam specs are a bit much in my thoughts.
All that said the clutch will have to be slipped some to get moving. The right clutch will make all the difference in the length of life to expect.
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
In 1993 Mike made the first conversion of a Ford Tremec to GM 5-speed. It bolts to stock bellhousings w/out an adapter. The FE Tremec, the Mustang adjustable quadrant are originals from Mike.
One of 12 Tremec Elite Distributors worldwide for: T-5, T-56 Magnum & TKO-500 & TKO-600 ,Midshifter, Frt shifter, offset Vette shifter.
Est: 1981 selling performance parts to build your dream car...
