Thread: bleeding clutch
Old 07-26-2009, 01:12 PM
maxum_101 maxum_101 is offline
Originally Posted by rustyBob View Post
Thats just makeing sure the piston is all the way to the bottom of the cylinder and pushing all the air out..........you could bench bleed the cylinder and do the same thing before you install the cylinder then it dosent matter if the piston goes all the way down because there is no air in the cylinder.
thats the issue im having... it seems my cyl does not go all the way back, i can pull it back that little bit by pulling back on the clutch fork, when i let go of the fork it pushes back out again, could that be cause by having some air in the hyd clutch cyl ?
