Old 07-26-2009, 03:54 PM
gjkrv8's Avatar
gjkrv8 gjkrv8 is offline
Default Pulls slightly to the Left under hard braking
Hi All,
Just finished all the things I needed to do prior to painting and was doing a final "shakedown" drive and noticed under very hard braking there is an ever so slight pull to the left.
Wasnt sure if it was the road camber or not, but thought I'd ask the suspension guhrus for some suggested things to check.
Background information:
I am pretty sure my tyre pressures are the same but will double check.
Have fitted new RB74 RACEBRAKE PADs on the front and COMP2 on the rear. Only done about 20Ks with them. So might not be bedded in properly yet.
Had a wheel alignment done prior to Engineering and Rego. I am assuming that was done ok.
Suspension height is about 5mm different on front (i.e. Spring pre-loads)
Let me know what you think - put it this way its not a show stopper but I thought I'd ask, I might learn something.
Also does anyone have any low-tech ways to check Camber as I think my rear has a bit too much.
Thanks
Rgds
Gregg
