Thread: Injector Ohms
Old 07-27-2009, 03:21 AM
Default 1,3,6 could be hurting your ECU
olddog Those 3 injectors are in question. You could burnt out the injector drivers in the ECU depending on what system you have, Batch fire (4) or sequiential fire, (8) There is a basic test to charge the injector and check amp draw on each. This works for GM not shore about others. Rick L.
