Thread
Pulls slightly to the Left under hard braking
permalink
07-28-2009, 04:26 AM
RICK LAKE
Can you swap pads from side to side
gjkrv8 Gregg can you swap pads from right side to left? If so do it and see what happens. If it pulls left you may still have air in the brake lines or a pinch in one, if pulls right, it's the pad material. Did you break in the brakes easy for the first 500 miles?? If not you could have glazed the rotor and this will give you poor grip between the pad and rotor surfaces. Try the swap first and bleed the system again. Rick L. Have to ask How much you weight?? Was the car alignment done with your weight in the drives seat? Same for ride hieght.
RICK LAKE
View Public Profile
Find all posts by RICK LAKE
