  #30 (permalink)
Old 07-28-2009, 05:52 AM
gjkrv8's Avatar
gjkrv8 gjkrv8 is offline
Originally Posted by gjkrv8 View Post
Hi Mando,
Am going to be doing some work on mine this aro. I found that on the rear stay I am able to use the rear stay "Oval" rubber with the "Circular" Bezel. Although in my case I will need to file/sand the Metal Bezel a fraction - I think I will use the Dremel for this.
Will post some Pics once I get this sorted.
One of the challenges I face is that one of my front circular Bezel fitting locations (the one closest to the edge of the body), the surfce is not flat. I might need to bend the bezel slightly - I am not looking forward to that as I dont know how pliable the bezel is. Gently gently will be my approach.
Rgds
Gregg
Hi Mando,
I received the Bezel from you in the post today, thanks for that.
Regarding trimming the grommet, I had to trim the edge of the oval grommet and I used scrissors and then the dremel and then hand sandpapered the rest.
Might not be able to post photos as painter is coming tomorrow night for an inspection before I rip everything off the car for sanding/filling/painting - getting excited now.
Rgds
Gregg
