  #21 (permalink)
Old 08-05-2009, 04:01 AM
strictlypersonl strictlypersonl is offline
The easy way to determine the major problem is to compare the temperature along the hot (temperature) wire. If the temperature is relatively even along the length, there is a high current draw. If the wire is hot only in a small section, then the problem is in a connection or (not likely) a partially broken wire.
