Old 08-05-2009, 03:31 PM
Default Simple fix for problem
Fastz06 Fast here is a easy fix for your hot wire problem, I am going with the fact that you have good grounds on the motor and chassic. 2 from the motor to the chassic, 2 from the battery ground to the frame and motor if the the battery is under the hood. Next you need to run a RED #4 gauage wire from the pos+ of the ALT out put to the battery. This will stop the over load of the amp meter and cut out the heavy draw. The amp meter will still work for any amps being used through this power feed. The battery is getting a direct recharge through the #4 wire. This will save the meter. The other idea is to replace the amp meter with a volt meter. You will still have to do some wiring for this to work. A voltmeter makes more sense than and AMP meter but is not orginial to a cobra. The other problem is how much ampage is being run through the meter. 30-40 amps is OK, more than this, is not the best way. I am going from a 70A alt to a 130 amp (3G) setup. I am going to a voltage gauge also. At Idle what does your amp gauge read about? with the basic electrical in a cobra, lights,3 fans, blower motor, and an MSD setup you are at the limit of the charging system at 55-60 amps. MSD system with HV coil uses more than 6 amps at 6,000 rpms, more like 12-15 amps. Rick
