Correct, McLeod has two Long pressure plates available. One that is meant as a stock replacement or a little higher, then one that is quite a bit higher for high performance engines. Any 11.5"/12" Long pressure plate should fit your pattern.
As for upgrading yours, I'm not for sure. If your clutch shop says they can, then that's an option.
