Old 08-06-2009, 02:08 PM
Snake2998 Snake2998 is offline
Cobra Make, Engine: Shamrock
The simple answer is that on the track a well engineered light car will be faster in every way, except maybe acceleration, than a similar well engineered heavy car given the same power to weight ratios.
On the road it doesn't matter nearly as much because to overcome weight you can just add power - that might mean adding more weight and cost but then adding lightness is also normally very expensive in it's own right - especially if properly designed and engineered.
