Old 08-06-2009, 10:53 PM
SF_SN888KE's Avatar
SF_SN888KE SF_SN888KE is offline
Cobra Make, Engine: Cutting Edge Replicas, 427 World block SBF, TWM Injection
FWIW, sent in my Aldan double adjustables to be re-valved softer (testing different shocks and springs). Discovered one shaft was bent. They replaced the shaft under warranty - no charge (purchased over 3 years ago. Less than 4000 miles on shocks.) They came back polished! Only 100 miles since re-valve, no leaks yet.
Can't you change the bushings or bearings to fit 5/8" on other brands? Are your springs too soft, bottoming out, and blowing up the shock?
Ron; SF_SN888KE
Cutting Edge Replicas 427
Shell Valley Daytona #27
