Old 08-06-2009, 11:57 PM
CHANMADD's Avatar
CHANMADD CHANMADD is offline
The parts are available from numerous sources.........like your local NAPA or similar.
The lower front ball joints take a little doing as they have to be shimmed to get them just right..the kit comes with shimms.
The upper ball joint sits between the control arm arms and is adjusted front to back ..withh shim......this is he caster adjustment.
The upper control arm fulcrum is attached to the frame and has shims between it and the frame....this is he camber adjustment.
Toe in.... I like 1.5 degree of toe in on all the whells ....front and back.
Camber ....1.5 degree on all four wheels.
Caster.... if remember right is at 3 degrees.
john
