The vacuum advance should always be disconnected when you are setting your timing, otherwise it will affect the reading you are getting.
I also have to correct Jeff. 20 degrees of crankshaft rotation is 10 degrees of camshaft rotation. The crankshaft rotates twice (720 degrees) for every rotation (360 degrees) of the camshaft.
John Hall
