Old 08-08-2009, 08:46 PM
wideglidejoe wideglidejoe is offline
Cobra Make, Engine: FFR MK III,462 FE/TKO 600, IRS w/3.27
Default Can anyone recommend.........
someone to set up a ring and pinion in an IRS? I've got an IRS w/aluminum center section and 3.73 gears. Too steep for my stroker FE. I'm thinking I want to go to 3.27's unless someone talks me in to 3.08's. I'll be running a TKO 600 w/.82 5th behind the FE.
Just looking for someone that does good work in the Tulsa metro area. No big rush, I haven't pulled the center section out yet, nor do I have the new gears. Just need a name and number for when the time comes.
thanks in advance,
Joe
Wideglidejoe
FFR#6143 Mk III: FE 462" w/four 48 IDA Weber's w/TKO 600 .82, IRS w/3.27, 17" Team III's w/245/45's & 315/35's. Gas N's.
Picked it up end of Aug '08
First start May 12, '10
First go kart May 26, '10
Tag & title 5-26-11, driving in gel coat
Painted Nov 2015
'05 Harley Wide Glide (60 hp stock, now 107 hp & 107 ft/lbs at wheel. Mid 11's in the 1/4 mi.)
'55 Bel Air hot rod project (WIP)
