Old 08-10-2009, 01:19 PM
Tom Kirkham Tom Kirkham is offline
CC Member / Sponsor
Originally Posted by MaSnaka View Post
... I know some TL's have the speedo outlet on the driver side and some on the passenger side and possibly some yoyo replaced the speedo gear with the wrong part being left hand or right hand. Or do the speedo cables all rotate the same and it's the rev. speedometer that makes the change in rotation? My gear outlet is on the passenger side of the trans case. Thanks for your replies. John
The Galaxie 4 speed, the 3 speed transmissions and autos used the same speedo drives. If you put the gears from the Galaxie transmission into the other 4 speed boxes (like a Mustang) it will turn the speedo cable backwards. You can also put the 4 speed speedo gears into a Tremec TKO transmission to reverse the direction of the speedo cable...
Cubic Performance
HiTech Legends
https:HiTechLegends.com
Evolve Lubricants
https://evolvelube.com/
