Old 08-12-2009, 01:14 PM
MotorcityCobra MotorcityCobra is offline
Cobra Make, Engine: Classic, 347
Default Dv
Thanks, DV
Threaded hole was too close and I ended up messing one up (maybe repairable with bottoming tap). Second insert I was a little smarter and put the screw in the hole before hitting it.
Also noted the side arms are bent to different angles (way different angles). Looks like I'll have to measure the car to figure out which one is correct. My luck I'll probably end up bending the good one to the bad one's specs, then I'll have to bend both of them back to where they should be.
Regards,
MC
