Old 08-12-2009, 11:20 PM
bobcowan's Avatar
bobcowan bobcowan is offline
Originally Posted by nymathboy View Post
Hey guys,
I needed to replace the throw out bearing. I got the new bearing in and found out that the bearing isn't going far enough forward to touch the pressure plate fingers. I am assuming I need a longer pivot stud. The stud was a PITA to get out. I had to take the bell housing off to get to it.
How long of a pivot stud do I need so that when I press the clutch the clutch fork will press the Throw out Bearing against the the fingers of the pressure plate?
You're exactly right. I had the same problem with mine during initial assembly. My Ford Tremec bellhousing that I bought used had an aftermarket adjustable pivot stud that measured 1 3/4". Just like yours, the throw out bearing didn't move foreward far enough to work the clutch.
With the throw out bearing touching the fingers of the pressure plate, you should have about 1-2 finger widthes (2-4cm) from the rear of the square hole to the rear of clutch arm.
Get a stock replacement pivot stud from Mike or Ford. It should be 2" tall, and not adjustable.
Since it fit and worked before, and doesn't now, you can only assume that the previous throw out bearing wasn't the correct part, or not a direct stock replacement. I now use only Ford bearings, as recommended by by people I trust. So when I replace it, it always fits.
