Old 08-13-2009, 03:29 PM
patrickt patrickt is offline
Originally Posted by saltshaker View Post
are you saying that i can bleed the MC and forgo bleeding the calipers again?
Maybe; but you won't know until you try. Put plastic tubing on both of your master cylinder bleeder valves and have the tubes run back in to the reservoirs. Then pump, pump, tap the MC with the back of screw driver, pump, pump, pump, until you see no more bubbles, then pump some more, tap some more, pump some more, and then tighten up the bleeder screws and carefully remove the plastic tubing that is full of fluid. If your pedal is still soft then you'll have to bleed all four wheels again.
