Thread: 48 IDF jetting.
  #26 (permalink)
Old 08-14-2009, 02:02 AM
Caprimaniac's Avatar
Caprimaniac Caprimaniac is offline
Cobra Make, Engine: Unfortunataly ; none
Default After sun comes rain
Or after boilings comes ice.
Did a couple of hours with broadbandmeter last night. A/R abaout 11.5 at full throttle. Too rich, I know.
Did some reading and found a formula: Main venturi *4= main jet size= 160
I did put in 165, so that's a fit.
But then: Air corr.= main jet + 60 = 225... I have 190 (drilled to 200...)
Will try to change to 135 mains; fits the formula. Will get a set of 225 or 230 later to go with 165.
Also:
Went autocrossing last weekend. Bubbling sound and hestiation at around 4000- 4500.
Drove to pit & parked. Had a feeling of boiling gas in the float chambers (as I previously have experienced.) But no; THE CARBS WERE ICE COLD.
Same happened last night; after going through 2. and 3. to 7500 rpm, the engine stalled in 4. @ 4000 rpm.
After parking, again, carbs icecold...
Conditions: Humid (rainy), 52 F (11 deg. C). At autocross it was not that cold, but same humidity. Have a large front scoop and "double hood" with a closed chamber surrounding the air horns of the carbs.
And, in addition to the icing this happend: After 1 hour of highway speed (60 mph) my gastank went empty! Wow! I cannot see going up +030 in a mainjet can cause this, but....
Can someone confirm: Can carb icing be the cause of the hesitation in 4. at around 4000 rpm?
I will try some alcohol in the tank to see if that helps. Any other ideas?
Also: Sudden explosion in gas consumption. Can icing conditions be the reason?
