Hi JC,
Assuming you're not getting a rolling kit, you could do the following:
Get the suspension stripped down, passivated and rebuild it, this will take some time (especially getting the hubs right), I would start with that. Roadbend Jaguar will be able to help you with suspension components.
You could get all the components for the brakes rebuilt, I got mine done at Perth Brake Parts - they could also supply bundy tube, new discs etc.
A steering rack will also help early on.
That should get you a rolling chassis.
I found it was the small components that took most of the time, mostly brackets, oddball size bolts etc.
Andrew
