Old 08-14-2009, 09:55 AM
Tony Ripepi's Avatar
Tony Ripepi Tony Ripepi is offline
Cobra Make, Engine: TBD
Argess,
Sometimes there is a misfire due to crossover in the plug wires on the rear drivers side of the engine. You can not see it during the day but fire it up in the garage with the lights out at night you see the crossfire, if it is happening, high humiity and heat are the culprits. To fix it simply redress/reroute the plug wires. I have sprayed a mist of water into that area to see if the humidity is also a contributing factor.
Good Luck....
Tony R.
