Old 08-16-2009, 05:54 AM
blykins blykins is offline
Double check to see how far the TOB is out, adjust that, then bleed it.
You can easily check to see how you're doing with the car up on stands. Put the car in gear, then have someone try to turn the rear tire. When you push the clutch in, they should be able to turn it.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
