Old 08-17-2009, 08:57 AM
Wbulk's Avatar
Wbulk Wbulk is offline
Cobra Make, Engine: 66 Cobra
Comp Cams has a free computer program that you can download to help you pick your cam. You put in everything about your engine, car weight, intended use, and it will give you serveral options with all the specs, and if special springs etc. are required. Most people over cam their engine and don't normally run in the RPM range the cam was intended for.
Wayne
