  #21 (permalink)
Old 08-17-2009, 11:26 PM
Jamo's Avatar
Jamo Jamo is offline
Super Moderator
Originally Posted by car4jim View Post
Thanks Franklin. Makes total sense. I'm going to proceed to cover the lower piece only.
On the floor mat pieces...did you use the pins/clips in each 4 corners per Kirkham, or just glue the floor mats down. I like the idea of being able to remove them, but seems like a more robust intallation to just glue the whole thing down. If you used the Lift-A-Dot clip arrangement (4 per mat), does it work well?
Yes, we treat sheep muy goodo...love dem, eat dem, wear dem.
I've got wool and they installed it in Provo with the lift-a-dots, which is the bestest thing you can do. Pull them out when damp.
Only wear I experienced was on the driver's side due to size 13s...had a nice rubber heel pad sewn in a couple of years ago and it's been muy perfecto since then.
The carpet's been wet more than a few times...pull out the mats and let them dry...no problemo.
Jamo
