Old 08-20-2009, 04:00 AM
Double Venom's Avatar
Double Venom Double Venom is offline
Tim is spot on, unless you find some one with a CR's with a Chevy BB, the chances of finding headers for it THAT FIT CR,s is going to be nil to -0. I of course could be wrong but it would be a rare bird.
Without a JIG or blueprints the fabricator is going to need your frame with the body mounted, the side-pipes, and most likely the engine in the frame.
There is one guy that I know of that may be able to help you, (Jeff- in Ohio. A CR's builder and fabricator does make headers) his number is 419-919-2277
HINT: Don't forget to tell who ever fabs them up for you the left front tube (#2 cylinder) has to extend out farther from the rest, so the steering shaft has enough room to pass through the headers.
If you were closer I'd make them for you.
DV
